1 - 13 of 13 Posts
I have a very bad shudder in my driveline till 30 mph when towing heavy, what would be my best be, Traction bars, or Air bags. if i get the traction bars they with be PMF's and the bags will be the firestone ride rites
I have the same problem when towing heavy, I'm curious what people say. Bump
Sent from my Autoguide iPhone app
Details would be helpful....are you lifted?? When does it occur...constant, (during any/hard acceleration, no acceleration, slowing down)?? When taking off from a stop, after shifts, all of the above)? Are you running the 210 Tow tune?
I am not an expert on suspension, but details may help.
tuned or stock dosnt matter, only when im acclerating from a stop to about 30 mph it has a shudder, 1/8 throttle to wide open the shudder never seems to get worse. Stock F350 hight and its a single wheel.
So this is basically constant from 0 to 30 and doesn't vary (such as being worse when you first take off or during a shift)? Traction bars help if your problem is axle wrap. Usually axle wrap will occur either when you first take off, during a change in the rate in the rate of accleration, or during a shift (especially if you have shifts on a tow tune) but it wont stay constant during acceleration from 0 to 30. The driveshaft stock is usually at a slight angle to the rear end which is why your block on the rear end has a slight taper but since you are at factory height I don't think we could blame it on a driveline angle problem.
What weight are you towing? Is it a goosneck or 5th wheel? Any possibility it is your TC?
StackinChipsLikePringles
U joints either binding up or going out. I would do traction bars
carrier barring is the problem, still putting bars and bags on it. and i tow heavy about gross out sometimes near 32,000. but i mostly haul hay which total load not including trailer and truck is around 22,xxx lbs I knwo before anyone says im working it to hard. i know i am so no need to tell me that.
Holy sh#t dude!!!!!! Now that is getting it done. Definitely think bags and bars would be a good idea!!
I love seeing pics of our trucks towing heavy. If you have any, would you mind posting it?
lol depends on the size of the bales, 5x6 i haul 15. 5x5 i haul 17 or 18 just depends if i put 2 on the neck or not. silage bales i only haul 10 because they are very heavy lol. ill try and post some pics if i can get them to load.
Wow we haul 17 5x5.5 on our 450 or most of the time use our western hauler package peterbuilt. No way would I hook it to my truck lol
lol, we load um heavy around here. and honestly if i had a bigger trailer i would prolly put more on it haha. i need a bigger truck a 450 would be nice because of the bigger brakes.or at least a manual so i could drop gears.
1 - 13 of 13 Posts
