1 - 2 of 2 Posts
out of town in kentucky, its 2 degrees outside and i noticed a small drip at the front of engine, dripps down on steering rod and then to ground... anybody got any ideas, thinking weep hole on water pump and could this just be because it is so cold outside. please respond:ford:
Vtwinrunning
Morning is it red, green, gold, oil, water, or what does it look like exactly, that should tell you what it is. True ford coolant is kinda yellow/gold in color unless someone has put in green coolant. Transmission fluid is red along with powersteering fluid. Some powersteering fluid is also clear. No matter what temp it is outside you should never have anything dripping, did you do all the updates?
1 - 2 of 2 Posts
