1 - 5 of 5 Posts
diesel fiend
The dealer told me years ago to use the gold or G05 coolant in the 6.0 without additive.Just make sure to use distilled water if you are flushing and refilling.
You need to do few things to your 6.0 you need to ditch the Ford Gold junk of a coolant that kills the oil cooler get a coolant filter to remove the casting sand and do a good flush useing Restore and Restore+ then install a CAT EC-1 Rated coolant but first get a good set of gauges to see what your deltas are between ECT-EOT max is 15* i think if you are at 10* doing 60mph on flat ground after 3-4min your coolers are in trouble and the Edge Insight CTS or the ScanGaugeII work well for this.
2 stroker
1 - 5 of 5 Posts
