1 - 12 of 12 Posts
Yesterday my converter stopped locking up. Took it to a trusted trans shop and hooked up a SnapOn Scanner. The truck is throwing no codes, but in real lime logging, the ecm is commanding the converter to lock. Since the ecm is commanding it, and there is no codes being set, does that mean the converter is getting the message and locks but it’s just slipping and therefore the ecm can’t detect the mechanical failure? I have been getting the code for converter lockup failure off and on for the past year. It would set the code but it still locked up fine.
I would look at wiring before jumping to worst case scenario. Lol
We looked at that yesterday and it all looked good visually. That would be the harness going to the trans correct? Funny thing is, when going down a slight decline or perfectly flat ground, it feels like it locks. 2600 rpm @ 70 mph when going up an incline, 2100 when on flat surface or slight decline. Accelerate just slightly, and it jumps right back to 2600. Is it possible to just partially work?
College Student
Whats the tranny fluid color on the dip stick?
Looks new, smells new. Its 6 months old.
Former Ford Trans Engr.
The PCM can detect a mechanical failure. You were getting the code, it just hasn't set again, yet.
What does the front face of the torque converter look like? When the converter clutch slips it heats up the front of the converter, which will blue it, similar to a gun that has been blued.
A visual inspection only finds the most obvious problems. A bad harness usually looks fine.
Having said that, the electrical tests that look for opens and shorts in the wiring harness are the most robust tests the PCM runs. If there were an electrical problem there would be a code for that.
Yes, it is. That would cause the front face of the torque converter to turn blue.
I drove the truck all day today and no converter lockup, and no codes thrown. Perhaps it’s just complete coincidence, but this evening I looked under the hood and the vacuum line to my map sensor had blown off. I reattached it and installed a hose clamp. Now the lockup is working again! Wtf???
By front face of the converter, it that the side that faces the trans?
Discussion Starter #9
Do I even need a triple disk billet or a single disk billet ok? Daily driver truck in sig.
Check the 3rd brake light on the cab and your rear brake/tail lights. 3rd brake light and rear brake lights not working can cause issues with TC lock up as I recall. Ensure they are working correctly.
j
Face of the converter looks good, but I’m going to replace it.
1 - 12 of 12 Posts
