1 - 15 of 15 Posts
Thanks guy's I have received the package and the kit looks really nice. Cant wait to do the install next weekend if I can find some pipe. I will post some pics as well.
Haters Gonna Hate
what did u order? been debating this traction bar idea
Sorry it took so long to get pics up but they work awsome. Thanks
Smell My Finger
Do you notice any suspension binging. And what is the length of the bar. I am building my setup now and worried i might be to long and may cause problems.
Mine are 8 feet long and dont notice any suspension differnece...
Could you not mount the frame mount to the frame? And this is a bada$$ kit, seems like a hidden gem.
Haters Gonna Hate
what else are you going to mount it to? thats why its called a frame mount.... you could always bolt them instead of welding but apparently danny prefers to weld as do I... have fun drilling your holes
Well i just saw it looks like he made that box thats welded the the frame and i just assumed the frame mounts would be welded directly to the frame without making/needing that box. Unless im mistaken and that triangular box comes in the kit.
Metal - It kicks your ass
Depends on where you place the bars. You can mount the bars to run directly under the frame rail but then you need to remove or modify the sway bar because it will be in the way.
Or you can mount them to the outside of the frame rail but, depending on the axle mounts the u-bolts will get in the way.
Mine for instance I mounted directly under the frame but i also had to remove the sway bar.
Take your pick.
Thank you that answered my question, thats exactly how i plan to them. And i dont have a sway bar so that shouldn't be a problem.
1 - 15 of 15 Posts
