Again this is for the New PSD guy to give a few pointers and hopefully answer some FAQ's.
1st off the choice of filter is your choice myself I like the reuseable cone type, some prefer the Napa 6637 and simular open element style paper filters. The instalation IMO is the same.
What you will need. Drill/Driver, 1/4 socket bit, 10mm socket, 5/16 socket, prybar, and piece of tubing to connect new filter to old intake hose. I used a "used' 9" long piece of 4" exhaust pipe I had laying around cleaned/deburred.
Start by removing the airbox and intake horn, the box top screws are 1/4 square, use a 1/4 driver bit or ratchet/extension. The horn is held by a 5/16 hex. The air intake hose will need to be losend from the box top, 5/16 worm clamp. The box base is held by a 10mm nut on the rear drivers side, top right of box. In the lower right corner you'll see the air temp sensor it will twist out like a parking lamp bulb.
To removed base use a prybar to move the passengerside rearward to pop out of the rubber gromet seen here next to the bat. Once that 1 is free turn box clockwise and repeat on the drivers side gromet.
The rest is as simple as connect the dots. Place tube into factory intake hose then fiter onto tube and snug the worm clamps.
Use zip tie (not shown) to secure sensor to filter. And you're done
