DIY Fuel System...now with pics
OKay, trying to gather up parts to build my fuel system to support the new injectors. Would this set-up work?
ITP in tank set-up then into a water seperator filter with a dual inlet/outlet head. Run two lines out of that pre filter, one to two seperate stock oem fuel pumps, then run the lines off those two pumps into a dual inlet/outlet filter head with a 2 mic filter. One line coming off each outlet feeding directly to each head.
So i would be running one pickup into the pre filter, then dualing everything thereafter to each head... Would that work, or would dumping both pumps back inot one post filter cause a rerstriction?
Any suggestions? Or ideas? Just trying to figure out the best way to do this
