1 - 8 of 8 Posts
I have the whole electric fuel system on, the pump is running, but not drawing any fuel from the tanks.
I even filled up both filters, thinking there may have been air in the system.
That did nothing.
I have not checked to see what the regulator is set at, but the pump should draw aleast a little fuel shouldn't it?
I am 99% sure i have the system setup right.
I Used the fuel line closest to the frame comeing off of the selector switch. I also made sure, by following the supply line from the top of the motor.
Could i have a bad pump, i hope not, but atleast i will know what is going on.
Anyone that can help or has an idea, please awnser, i need the truck for work!
Have you unplugged the end going in the truck to see if it would pump free.
I checked the lines going to the pump, nothing, no fuel at all.
I even turned the pump around and still nothing.
Ill have to try to take one of the lines off and see if it even sucks air? could that hurt the pump worse?
Open filler caps on both tanks. Remove line to engine and let fuel flow into bucket.
USASF Retired
USASF Retired
Found it...........
1 - 8 of 8 Posts
