1 - 3 of 3 Posts
I currently have an AirDog II but am considering changing things up a bit. The AD filters end up hanging just slightly below the frame rail which I would like to eliminate.
So, if I go with a SD pump is there a filter and water seperator that would be short enough not to hang below the frame?
Pre-K
Can you move it to the middle of the frame? I don't think it has to be on the outside?
What's the length on your AD? I'd just go to ff or similar (napa) and compare sizes. Get a water separator that's not as long.
Mounted mine inside just behind the transfer case they are (filters) just short of sticking below frame. Have pix and info in sig link under red truck and black truck folders.
Cheers
jrc
1 - 3 of 3 Posts
