1 - 4 of 4 Posts
Like the title says I have a ? about leveling my truck.. Except I wanna do it from the back, lol.. It's an 04 FX4 SuperCab.. Instead of lifting the front to level it I wanna drop the rear to even it out with a nice set of rims.. It's rarely off road except deer season and even then it's not bad.. So I need some pics or info on the best way to pull it off.. Thanks in advance!!
Take the blocks out that are between the rear axle and the springs. There 2 inch blocks so that should put you pretty much level.
Big dumb *******
:whs: should get you where you want to be.
Where is Aberdeen? I'm up north right outside Memphis.
Premium Member
F250 has a shorter block than the F350 SRW. A DRW has a shorter block than the F250 so you have some room.
1 - 4 of 4 Posts
