1 - 8 of 8 Posts
You might want to check the first 4 digits again. I can't find the F7TZ on the PCM code list
The F7TF-TB looks like it came from a 96 with a automatic with a code of TDE1
Any 48 state will work auto to auto DPC 202, same for stick to stick DPC 203.
Discussion Starter · #5 ·
Ford F7TZ 12A650 TB Engine Computer ECU PCM Engine Control Module | eBay
It's also listed here
http://www.rockauto.com/dbphp/x,carcode,1118045,parttype,2896,d,1995_FORD_E-350_ECONOLINE_7.3L_445_cubic_inch_V8_DIESEL_FI_Turbo_F_Engine_Control_Module_Computer_.html
It seems the F7TZ-12A650-TB is a TDE1 and the F7TF-12A650-TB is a TDE0. The truck it's for is a ZF5 swapped auto.
Thanks guys
Discussion Starter · #8 ·
So I sent my ECU out to get flashed to a manual. Tuner called me to tell me the ECU was bad.
Got it back and the truck runs fine
....wat
1 - 8 of 8 Posts
