1 - 15 of 15 Posts
· Registered
I just received my new OE Ford finned aluminum rear diff cover from Bob at PowerStrokeShop.
Now I one quick question. How is it sealed to the rear?
The cover has a groove milled all the way around the flange, looks like an o-ring groove. Is it?
Or is it just installed with some RTV like the stocker?
TIA.
MrBill.
· Registered
Just use some grey RTV such as Loctite 599 and you should be fine.
· All done now
In case nobody mentioned it, some silicone will do the job for you.
· Registered
Discussion Starter · #7 ·
Yea, but has anybody tried silicone?
· <- Sums it up
Permatex Ultra black silicone
· Registered
I'm not sure, but I think someone did say just use silicone. Silicone should work.
· Never Fry Bacon NAKED!
There sure is a lot of this stuff being bandied about in this thread!
All joking aside...
Apply a new, continuous bead of sealant to the differential housing cover.
Use Clear Silicone Rubber D6AZ-19562-AA or equivalent meeting Ford specifications ESB-M4G92-A.
NOTE: The differential housing cover must be installed within 15 minutes of application of the silicone, or new sealant must be applied. If possible, allow 1 hour before filling with lubricant to ensure the silicone sealant has properly cured.
Install the differential housing cover and tighten the differential housing cover bolts.
Stewart
· Registered
I don't think I'd waste that good silicone on a diff cover, I'm SURE I can find something better to use them on.
Loctite 599, aka Cummins Grey, aka Navistar Grey. We use that to install all of our Meritor/Rockwell diffs. The 599 takes high TQ loads much better than other types of RTV. If it had much of a chance to leak we wouldn't be using it, no one wants to pull a diff twice. They are big and heavy and you have to move a lot of other big and heavey stuff out of the way to get them out.
1 - 15 of 15 Posts
