1 - 6 of 6 Posts
Is there any difference in the 2 axles as far as the cover? I'm looking for a new front cover but I think the 60's work on the 50's but could someone correct me if i'm wrong please before I order the wrong cover.
Thanks
^^ correct. Just put on my MagHytec covers. Says 60&70 on packaging
ate lug
Im guessing youre looking for a D50 cover.
The D44 TTB 3rds & the D50 TTB 3rds are interchangeable (both can be bolted into the same TTB arm), which means you could have put a D44 cover on a D50, if there was a such a thing back then. My guess is, Dana didnt change the bolt spacing when they built the live axle D50, and a D44 cover will still fit.
If you are a referring to a 99-02 SRW SD with the solid axle D50, the D60 cover should work. I have a D60 cover on the D50 under my 2001 F-350 SRW.
1 - 6 of 6 Posts
