1 - 2 of 2 Posts
As title says, I was towing a dually with my 07 6.0's yesterday and while cruising down the interstate it randomly shut off and would not restart. Crank crank crank nothing, had someone tow the whole load and I to a fuel station, still nothing. Well I got it back to the shop now and pulled codes, I know it always had a bit of a miss to it, so I had a set of injectors I was going to put in it soon but it ran fine unless idling, The FICM reads 12.00 main power and 3.00 3.00 while sitting. So I pulled the cover off the FICM, manually checked it and that read 48.6, 13.56 and whatever the other voltages were they were fine.
Anyone else ever had or heard of an issue like this? I had the cab off 3k miles ago (2 weeks) and put studs in etc. Im thinking a wires rubbed through or a pin pushed out between the FICM and the ECM or the cab. I cannot build over 49psi oil pressure either. If anyone has any ideas they would be welcomed, I will start tearing it apart right now but and see what I can find.
1 - 2 of 2 Posts
