I had the exact same thing happen once, turned out to be a bad case of stiction. Get some archoil or rev-x and see what happens.
good to know thanks guys going to probably try one of those additives. Probably been asked before but where do they sell them at? im new to the diesel world.15qts is correct, so if that is what you used you are ok. To use the dipstick you need to short stick it...Put the dip stick back in until the black handle touches the metal tube but don't push it down. Just touch it to the tube then pull it out. If it is full it should be in the middle of the bulb or a little lower. If it is at the top or above then it is over filled. As said, 15qts is correct.
It is likely the oil. For some reason it doesn't like the delo, which is good oil. Try the rev-x or Hot Shot’s Secret Stiction Eliminator. It won't hurt anything and may help.
Beats me... but you can start here.good to know thanks guys going to probably try one of those additives. Probably been asked before but where do they sell them at? im new to the diesel world.
