1 - 9 of 9 Posts
The Oracle
if any one has used the DI fuel fittings in the rear of the heads....
how did it clear the down pipe? 90* hose end and a (big hammer) ?
could you post some pictures?
I'm unexpectedly doing my fuel system(broke the stock regulator during Adrenaline install) :doh:
its not going to be exactly how i want, due to me needing to get it out of the middle of my shop, it but it'll be functional.
thanks
~Tim
HRT Performance
I didn't use DI's fittings but I used a 90* jic swivel and connected the hose to it. The down pipe was not in the way - but it was not in the "normal" position that down pipes are found in.
2010 BOB Points Runner up
I have them on my '97 with an H2E, I used a 90 degree fittig but took a wrench and bent it to be less than 90, maybe somewhere between 60-75
-Michael
OverFuelingForYourPlesure
I am running them in my 96 with out any problems, but I have a 2in body lift and am running a 3.5in superduty h2e down pipe that I modified to fit my truck.
I couldn't get anywhere to get a picture of the driverside but is is a lot closer, I had to run the line up and then back down to keep it from hitting the fire wall.
the only issue I had with them was the nut om my 90's bottomed out before the flare part did so I had to grind the bottom two threads off of the nut to get them to tighten down and seal off.
Village Idiot
Iirc the e99 takes some tweakn' might pm or call dave to see what they were.
1 - 9 of 9 Posts
