Tom S What programming are you running and what base code just for reference?
Jodys tunes, I forgot what PCM code, will check tonight and post.
Stroked95 Don't know so I will ask. Is defueling the same as loosing fuel pressure? If it isn't then to the OP have you checked your fuel pressure at WOT?
Defueling is the PCM cutting the fuel back, loosing fuel pressure is just that, loosing fuel pressure, Mine holds 67psi at wot
JAKE does yours have a 5speed in it? ive seen more of this with manual trans trucks
Yes, its a manual!
hotwheels I used to hit 35 psi all the time with my stock turbo. Never had a problem. However with the turbo I have now once I get to between 30 and 35 psi it starts surging really bad. Put a regulator on it and it goes away completely.
Was it surg or was it defueling? Are you the one that had the Live testing with Jody when he found it?
