1 - 7 of 7 Posts
BRING DA AMBALAMPS
I've taken my badges off so now i'm looking for some help on how to get that black sticky crap off. Also, should i just use some type of bondo to fill the holes? thanks!
If you have bondo in a place where air can get behind it, it will crack and not work good. Usually you need to weld the holes and sand them down, then use bondo to make smooth or just lots of layers of paint. Just the way I would go about it. But I'm not a pro either.
Offical Puddle Displacer
fiberglass would work good but welding would be ideal. do not use only filler it will crack pretty quickly and youll be doing it again
BRING DA AMBALAMPS
any ideas what a shop would charge to do that?
7.3
Weld the holes up, fiberglass, bondo, skim putty. That's how I did mine.
<-MONEY PITT!!
:whs: And to get the tape/sticky off from behind the badge use a drill and the stripe eraser.
1 - 7 of 7 Posts
