1 - 14 of 14 Posts
PETE ENGR PSD
My truck has always done the death wobble some, but generally only after getting my tires rotated and balanced.
I R/B my tires about 3000 miles ago, and my death wobble is still not cured. If I am going under 30 mph, and hit a bump/hole of some sort my truck starts to go spastic.
Starting off I think its a good idea to go small and just replace the steering stabilizer as I think the shock might be shot. Looking for some other opinions. Also, is DR the way to go for the shock, or should I be looking at another brand? Thanks... Just wanna get this dam thing to stop
Kevin
Its not in my sig but it is a 4 inch D.R. on 35's
PETE ENGR PSD
My buddy has the same problem. He has 10 inches and dual stabilizers about 10k miles on them.
I heard dual stabilizers nearly almost always fix it. I just don't want them. IMO they look odd..? But, if it is the road I have to take. Then I'll just have to bite the bullet.
Diesel Sled Head
Make sure to have your tires aired up also on the high end of the spec. Seems to help.
PETE ENGR PSD
Tires are correct +/- 2 psi. I recently checked the tie rods they were okay.
Whats the negative caster? Not very good with suspension here.
Check the ball joints and the steering box for looseness.
My track bar bushing went out and the bolts in the track bar bracket that go across the frame had come a little loose and was alowing the bracket to move a little everytime i turned the wheen and thats waht cause the track bar bushing to go out after replacing that and installing a new track bar bracket the wobble went away.
Did you install the lift Kit your self/ if so id be checking that track bar bolt cause it needs to be torqued to like 250 ft lbs so if your dont have something capeable of that, that could be your problem
PETE ENGR PSD
I had it installed at Planet Pick-Up in San Antonio nearly 5 years ago (pretty reputable shop). The kit got put on only after about 500 mi of driving. I have a 400 ft/lb snap on torque wrench so I'll try to re-torque it this weekend when I am at my shop. Thanks for the idea.
no problem i know thats what caused my problem i was like you when it first started i was like well time for a new steering stablizer and come to find out i was wrong so there are many things that cause it but usually it is the stablizer but sometimes more and in my case it was more
PSN nerd
does your lift use drop brackets on the radius arms?
the caster angle could be off also, that is the angle of the steering knuckles I belive 5 degree positive is what it is supposed to be.
1 - 14 of 14 Posts
