1 - 9 of 9 Posts
The ECU was updated in 98 to f6tf-12a650-aue per a sticker on the engine cover. This appears to be a flash to 96.
Is this truck OBD2 now ?? Thanks for the help.
It should be as OBD2-compliant as a OBS PSD gets (looks to be an ALF4 code which is what my former 1994 was refalshed to). You would need use diagnostic software that has the "enhanced" Ford capability ( such as Autoenginuity, if that's is what you are after). Cheers!
Thanks a lot. I wish I could have realized this a few months ago but I failed to google the sticker numbers. I have been trying off an on the get the ECU to act on pre OBD buzz tests. DUH!! Figuring it out which injector dies next be a little less painful now.
Construction Babysitter
About how much does it cost to have Ford reflash the ECU? I think mine is still the original flash. There is a sticker on the HPOP reservior that says it is a 1994 flash and the calibration code is 5-89K-R. There is another number on the sticker that says 5G001AA.
When Ford did mine, they charged me 1 hour labor time (abou $75 at the time). You can also check with the folks at DP Tuner as I've heard they can reflash them as well. Cheers!
If it where me I'd go aftermarket like DP then you could be assured to get the best stock or slightly modified files. I would suggest most the dealerships would not know which are the best files as well they cannot tune to previous files only most current iirc.
jrc
TDE1 is what you want :)
Captain Negativity!
Powerstroke was the first vehicle to get OBD-II. It's been that way since 94 when the 95s came out. Everything else got it in 96.
1 - 9 of 9 Posts
