1 - 5 of 5 Posts
Big James
I installed a daystar 2.5" leveling kit and have a couple questions. First it says 2.5" leveling kit on the box but according to my measurement I only gained 2" up front, is that normal? Also I noticed that there are two notches on the block and used the lower one. If I used the top one would I get my extra 1/2"? Thanks in advance.
If u measured on the driver side they sag .5"-1" from factory. So yea that would be right. 2nd u put it In The correct notch, I wouldn't use the lower 1!
Big James
@JayZ-Thanks for the reply! That makes sense that these trucks have a sag to them from the factory. I didn't think the other notch would be stable enough to hold the spring it place, thanks for confirming I used the right one!
Let's see a pic....
1 - 5 of 5 Posts
