1 - 20 of 34 Posts
Okay guys did some runs and got these numbers at WOT. What do you think is it normal,good or bad?
Stock with chip still installed:ICP(V)=4.45
:ICP(PSI)=3306
:IPR(%)=74
:VSS(MPH)=87
80E 1st run :ICP(V)=4.41
:ICP(PSI)=3438
:IPR(%)=71
:VSS(MPH)=91
80E 2nd run :ICP(V)=4.50
:ICP(PSI)=3212
:IPR(%)=72
:VSS(MPH)=87
120R 1st run :IPC(V)=4.54
:ICP(PSI)=3572
:IPR(%)=77
:VSS(MPH)=92
140Extreme :IPC(V)=4.54
:ICP(PSI)=3572
:IPR(%)=77
:VSS(MPH)=92
Does these numbers look right? Stock HPOP....
wow wish i was helping you but here's a bump
HÄWÄÌÌÄñ
bump
FORD..THE ROCK CRUSHER
is that ICP holding at them ###'s ?? or is that peaked out then drop?? if its holding then DAMN you have a nice little pump there,,,,
I am thinking that peak. But could be wrong.
my thoughts as well..i believe he is running stock split too.. if its holding them ##'s then the Adrenaline would be a step back for him.... next time run ICP and duty cycle..that will tell you how hard the pump is working..
The Fireman
IMO your ICP is to high and so is your DC%
You really should never used over 65% DC or peak over 3100 ICP
But some people will argue with that.
On Edit: Would be nice to see the actual logs to make a graph out of and not just the peak numbers you see
P
Guest
The thing that gets me is the "stock" 3300 PSI with 74% DC. Stock programming will not allow those kind of IPR % numbers.
Okay guys I thought some of those numbers could be a little high from what I have read on this forum. Also still trying to farmiliarise my self with my modis scanner. I am trying to get a print -out of the graph. Is the injector pressure regulator the (Duty Cycle)?
pulsewidth, IPR DC%, and ICP pressure as well as RPM all on the same graph will tell the tale. Try and do a 3rd gear pull to give a long set of data.
So icp volts is not important? I would have to see if there is a graph with p ulsewidth. I will also look a the rpm's I think they where all about 2700rpm's . If I can only get a print out and show you guys :doh: then you guys can tell me what I am doing wrong or need to do. The reason for this test was to see how my stocker is doing. I have a moded 17 hpop in hand and wanted to if it would be worth the swap...
Thanks
post 15..click on his link..when it opens..click on the link in that post and you will see a graph there..
Discussion Starter #20
ICP volts really doesn't matter. It's the pressure number you're worried about.
I seem to recall that the IPR duty cycle maxes out at 60%, so I'm a little confused how you're getting 70%+.
Here's a little log I did for a guy at the track last month:
Powerstroke Nation - View Single Post - adrenaline+sled pull
Cowboy Dan what scanner did you use? AE? I would have to check my modis Iam sure it could check it that way. Anyone out there has a snap-on modis? I like the log that way .... you can see numbers through out the range.
Thanks Cowboy
1 - 20 of 34 Posts
