1 - 10 of 10 Posts
I am in the process of getting all of the parts I need to do a Dana 60 swap in my 96 F250. So far I have a Dana 60 out of a 91. It came with the tie rods, but not the track bar and mount or leaf springs.
I found an add on CL for 89 FORD F350 dually parts. They have front springs and the track bar and mount advertised. But the add doesn't state weather the truck is 4x4 or 2wd. Does it make a difference?
im a bout positive the dana 60 was only a 4x4 axle.
I know the overall design is different, I was wondering if those to parts would happen to be the same
STILL LEARNING
if they have a track bar and mount from a 89 FORD F350 dually then it MUST be a 4wd, because 2wds did not use track bars
Dont forget the riverside U-bolt plate too
OK thank you very much
Is this what you are talking about? (upside down)
STILL LEARNING
That is the Passenger side track bar mount/u-bolt plate. That is Part of the axle(permentantly welded to it)
You want the cast removable piece for the drivers side
This piece Part # E5TZ-5A316-A.
Looks similar but slightly different
Ok thank you. I don't think I have that part. Ill see if the guy with the other parts has one.
Ouch, that's expensive. I called the guy to see if he has it. No answer, I left a message.
1 - 10 of 10 Posts
