1 - 3 of 3 Posts
The other night drove home truck ran fine. Next morning i start it and it runs very ruff then dies and no start. I have driven diesel fuel bowl delete setting here so i start by installing it and make sure I’m getting good fuel pressure. I’m not so i put new fuel pump on. Still won’t run. Icp is bad i change it. Then i change the ipr. Try a different pcm. Last thing was change calve cover gaskets one was bad. Now it runs kind of i can drive it but it has no power will barely pull its self up a hill. I can floor it while driving and nothing setting in my driveway in park and floor it it will rev decently but still ruff. I tried a good idm no change. I’m lost as what to do next. Maybe start checking grounds?
You never did anything with the cam sensor? that would be the first suspect
Do you have a wait to start light?
Check your fuses?
This is a 7.3 Excursion how many miles?
Professional American, guarding our constitution.
CPS. Turn the wipers on and see if it gets more chaotic, then it's definitely your culprit.
1 - 3 of 3 Posts
