1 - 19 of 19 Posts
I started this project a couple of years ago. I got a hold of an "89 King-Pin D60 and rebuilt it, fabbed my own shackle reversal kit and track-bar mount, then set it up with V code springs. I got Bilstiens through CT performance. I love the ride, but I used the original drive-shaft and it vibrates pretty bad over 35mph. So I went ahead an got a new double-cardan drive-shaft but now I need to find the companion yoke for my 1356 transfer-case. I thought this would be easy to find (as it's not the 4407) but I'm not having much luck. If anybody knows of a good source, I sure would appreciate it! :fordoval:
Thanks!
Discussion Starter #2
Anybody?????
Pics of the yoke you need to mate up to would help a lot! Front or rear would be good too, I have a double cv in my f350 they came on single cab f350 diesels if I remember right. Gas output is different from diesel also so start searching at junkyards.
Get hold of Obswiz at CT performance think he has a solution for this iirc
jrc
FNM
I bought the ebay one. Not bad.
Looks like nice fabrication on your rsk kit. the 1356 shouldn't be that hard to find are they?
STILL LEARNING
They are the same GAS or Diesel, Reg cab or crew cab, Cab-n-chassis or pickup
From 1985.5-95 all F350 4wds had the 1356 t-case. I will see if I have enough spares to send you one
Thanks! it was a fun project.
I've called around, but folks keep telling me that it's obsolete?...yet from all the reading I've done on the forums it (1356 CV slip-yoke) seems as though it should be available.....hmmm?
Wow! that would be awesome. If you do have one, pm me and let me know what you need to have for it, as well as freight charges.
Thanks
Discussion Starter #16
Denny's Drivelines, Transfer Case Express, Tom's Differentials, Bronco Graveyard,NAPA, O'Reilly's,CT performance,etc.,etc.
Discussion Starter #18
But I have 4 axles they go with
No problem, you are wise to keep all that stuff together. Thank you for looking. It's surprising how difficult it is getting to be to get parts for this vintage of rigs. They don't seem that "old" to me...I guess I'm dating myself a bit!
Discussion Starter #19
I found one at a drive line shop in Boise....$25.00!! Now I just need to get it put together. Thanks for the replies to this thread. :fordoval:
1 - 19 of 19 Posts
