1 - 13 of 13 Posts
I will be buying tires in the next couple weeks. The tire will be a BFG A/T but am trying to decide whether to use D or E rated tires? I am leaning towards E because they have black walls. But how will the ride be effected?
Discussion Starter #2
bump
the d or e has a blackwall. e's are tougher, more ply's for more weight which means you can haul more.
I thought the Ds only came in white letter but could be reveresed, which I hate the look.
How's the ride on the Es?
Still learning
On 99.9% of tires that have white letters its only on one side so you can chose which side you want to show
i dont know about the ride on the e's, it might be a lil harsher but im sure a tire pressure adjustment could take care of that. ive got the d's with the white letters in i think all BFG AT's have one side black and one white so either way youll have white on the inside.
The Es have a black wall....my dealer has them in stock.
I'll go with the Es
Check to see the specific tire carry capacity intesting that some manufacturer rate differently, i.e some that are rated D actually will carry E rated of other manufactuer. In other works BFG AT "E" rated might have the same carry capacity as Dick Cepek Fun County II "D" rated at 3450lbs per tire.
I know that lots like the AT I used too as well....but have found the Dick Cepeks FC II to be a better longer lasting tire for what I do. 85% highway 15% off road. Check out sipping if you want max tire life too...
Scab
I like to use E range tires. I just think that they seem to hold up better under the weight of our trucks. Of course this is just opinion no actual evidence.
Need a ride.
JCart has a good point, some D rated tires might only be of load carring capacity by a hundred pounds or so so you should be good but just remember, and I know this because I went from a E rated 10 ply tire to a D rated 8 ply. The 8 ply has less stiffness going around corners and turning, meaning, more body roll so to speak. The 10 ply E rated are more stable and stiff on cornering. My vote if towing and better handling, E rated 10 ply at the least.
Word
When dealing with a heavy duty truck like a F250/F350 diesel, I would go with the 10 ply E load rated tire...for the simple fact of stronger sidewall and less flex in the tire...I run Toyo Open Country MT's 35x12.50 and they're E load rated....if you're going up in tire size than the stiffer the sidewall the better.
<---new toy
Ok here it is... D range tires are more suited for 1/2 ton trucks. only 6 ply's. If you drive fast like I do then they act like a drag tire. the faster you go the taller it get's, this means you wear the middle out sooner. Load range E tires are more suited for 3/4, 1 ton trucks. a D range has a capacity of max 60 to 65 PSI where the E's run a maximum of 80 PSI. you do not have to run the max in the tire. I have an 09 Dually and i run the tires at 55 PSI. they are load range E. there is a margin for you. The E's are more money, but you will hate it when you buy the D's and the tread is gone in 20 to 30 thousand miles. JMO
1 - 13 of 13 Posts
