1 - 3 of 3 Posts
Thirsty For More
Friend of mine has a 2006 6.0 Harley Edition, all stock, when hes driving and on the throttle it will cut out but it is especially bad from 55-75, even just cruising it cuts out and if he stomps on the throttle it will just cut out then die. Im not sure what the problem could be. Im guna try to drive it and give you some feedback next week sometime. Any help or troubleshooting??
Fuel it up again Dummy
Sounds like a injector issue until you say it will die at wot.
First thing:how long since the fuel filters have been changed and what is his fuel pressure running at ?
Me I would put in new filters and do the blue spring mod and go from there.
If problem still exists a ScanguageII would be a good investment you could start looking at ficm voltage,hpop,egr parameters and start eliminating possibilities.
1 - 3 of 3 Posts
