1 - 20 of 39 Posts
Hey guys, engine is almost built, just waiting for my transmissions to arrive...
Here is the specs on what I am doing,
Engine:
1993 Cummins engine
1996 O ringed cylinder head with 60lb springs
.020 head gasket and ARP studs
175HP P Pump, 100 plate, afc mods, 4GSK, Rack plug
181DVs, 15* timing
215 HP Cummins injectors
Colt Cams stage II cam
HX35 turbo with 16cm non gated housing
2000 Powerstroke IC
24V 3" IC tubes, turbo elbow and air horn
BHAF and 4" exhaust
1988 IDI non AC rad
Pryometer, boost, and fule pressure gauges
Transmission and Tcase:
2002 NV5600 and NV241HD
Valair DD clutch
Truck:
1995 Ford F350 CC LB 4X4 XLT
Was a 460 5 speed
3.55 gears
Factory Alcoa wheels
285/75R16 Pro Comp Xtreme MTs
Discussion Starter #2
Here are the only pics I have so far... not much but its a start...
Here is my swap truck:
Here is the engine so far... I removed it from the stand so I could spin it over easily for the pump timing and valve adjust
Transmission should arrive soon....
More pics to come
Before anyone askes, The front valve cover is being replaced by one with an oil cap...
Waiting on my NV5600, ordered my mounts and tach kit from autoworld MT today... Then its go time.... I will grab some more pics of other random stuff too....
I will keep the pics coming....
Custom Trailer Sales
Looks great so far. Very clean OBS to!
More engine pics
My nv5600 is still not here and the guy has not called me back?? Now Im thinking that my perfect shifting ZF with a destroked plate and a dual disk southbend might be whats going in??
Included in these pics are the autoworldmt mounts, ac mount and tach kit.... Also got the ford alternator kit but not shown
Discussion Starter #15
Thanks!!!!
Discussion Starter #19
cool... i may have missed it but did you make the motor mounts
Autoworldmt.com mounts... Built everything else but want to do the swap at my work shop... dont have the extra time to build mounts while the engine is out.... Going to try and drive the truck in as a gas on a friday night and out on a sunday a diesel....
indirectly strokin
that would leave people who know that truck rather confused lol keep us posted! pics are great too btw
1 - 20 of 39 Posts
