1 - 20 of 32 Posts
1996 F350 7.3 Powerstroke, zf5 swap, 160cc injectors, Wicked Wheel, ts6 chip, cold air intake.
Hello, I recently bought myself a 1996 F350 with the 7.3 powerstroke that was converted to a zf5. According to the previous owner the cruise control does work so I don’t know why it will not now. I checked, fuse is good, clutch safety switch is plugged in. I am thinking it may be my steering wheel buttons. My horn does work fine. Thank you. Anything helps
don't play well w others
Make sure the unit is plugged in under the hood by the booster.
  • Like
Reactions: 1970something
If
you don’t mind me asking where is that located? The cruise control is controlled by the pcm on the 7.3 if I am not mistaken
I'll have to look in the morning on my truck. Has been a while since I fooled with it
Discussion Starter · #5 ·
Would greatly appreciate that.
There should be a wire harness plugged in on the end of the brake master cylinder. If it has had the recall done there should be 2 fuses in the new harness.
Sent from my SM-J737V using Tapatalk
Discussion Starter · #7 ·
I do know for sure it has the recall I remember looking and seeing the 2 fuses is there anyway I can test if it’s not working properly? The fuses are not blown
Discussion Starter · #9 ·
does the truck had LED light bulbs in the back? they will effect cruise too.
Not if it has the adapter boxes.
Forgot to ask if his 3rd brake light is working. That will stop cruise if not working
Discussion Starter · #12 ·
I believe all lights are working and I am fairly confident tail lights are original halogens, interior lights are all led though.
The third brake light usually only affects cruse when the turn signals are used.
One of Fords better ideas.
Administrator
True that.
Did the truck get there with the bubble wrap yet?
Swmbo said she was going to wrap you up as soon as it got there😄.
Naaaa. Only broke my femur this time. No hospital stay
If you think it's the buttons, the stuff I posted i the other thread had information on how to test them (and the clockspring). Cheers!
Discussion Starter · #17 ·
I have attempted to test them and I am not getting any resistance unless the truck is off. Does this mean they are bad?
No, it means your meter (like most) can't measure resistance accurately when the circuit has another voltage source (the truck battery).
Discussion Starter · #19 ·
So what should I do? Buy a different multimeter? Disconnect the battery?
You should turn the key off when testing resistance, which is probably what the instructions Patrick posted say to do.
1 - 20 of 32 Posts
