21 - 40 of 56 Posts
Taters #2 Fan
My lights I dont think have ever worked. I know the coast button has always be flakey. But the cruise has always set fine. where do I get this coil and how hard is it to change?
Taters #2 Fan
Guess I will check that out in the next couple of days
I had the same problem as Speedy but there were no blown fuses...Just enough liquid in it to trip the connection some how. Either way, got it replaced and I haven't had a problem since. Might wanna make sure that's it before you start replacing the more expensive parts....I learned the hard way.
Speedy
Check that sensor on the master cylinder if its wet thats most likely the problem
Taters #2 Fan
I tryed jumping that plug and it still didnt work.
Taters #2 Fan
which sensor is it on the master cylinder?
Its the pressure switch out on the end/ top of master cylinder there is a two wire plug on it.
SLOW LEARNER
I have had 2 problems with my cc.The first was the brake switch.It was shorted just enough to kill my cc and flicker the brake lights once in a while.The 2nd which was similar to yours ended up being a broken tab holding the neutral safety switch in to the right of the clutch pedal.It had come loose and because I had bypassed the starting part long ago it took awhile to find the problem.
ΜΟΛΩΝ ΛΑΒ&
TERRCO- so all you did was fix the tab and it worked, or did you have to replace something? Just curious because I've also by passed the nuetral start switch.
Taters #2 Fan
My backup lights arent working either could that have anything to do with it? I just try and find that problem tomorrow.
Speedy
Hey JD 9610 my backup lights quit working once that pressure sensor shorted out I guess its on same fuse as the backup lights. Dont recall it being listed on the cover as on that fuse but it was.
Taters #2 Fan
I check all fuses and they are good. I used a meter on everyone so I know they are good. how does that pressure switch work? normal open or closed trying to check it with a meter.
Speedy
I'm not sure mine was just leaking fluid bad raound the top and the plug and when I replaed the blown fuse i seen small smoke and sizzle on the plug area right before it blowed the fuse. Is you pressure switch leaking fluid if not then you may have a different problem. Good Luck.
Taters #2 Fan
pressure switch is dry. changed the transmission range sel. On the side of the tranny and It didnt fix a thing. So now I'm way in the dark on this. No back up lights or cruise. I dont know if they are linked or not.
Speedy
:shrug: Don't no man.
OEM Moderator
Thanks Dave.
Tom
Discussion Starter · #40 ·
Brake Repair Kit for OBS, replaces switch on master cylinder
Replacement switch and adaptor harness around $20
Motorcraft SW-6350 or
1L1Z-9F924-AA
yes thank you - chris
21 - 40 of 56 Posts
