1 - 5 of 5 Posts
Hello there, I hope I an posting this in the correct section A few weeks ago I noticed that my horn and cruise control stopped working, and at about the same time, my air bag light on the dash board came on. I checked the fuses and everything looks good. Ironically, all are located on the steering wheel and i'm wondering if some wiring harness came loose or somethging or is it coiencidence that all three broke at the same time. I looked under the dash but did't see anything out of place, although i'm far from a mechanic. If anyone has any suggestions on what the problem is i would really appreciate it. :shrug: Thanks in advance, Joe
By the way the truck is a 2001 f350 srw 6 spd supercab diesel.
sounds like there is a good chance you need a clockspring if you could pull the airbag codes it might help..
clockspring sets right under your steering wheel and has wires connected to it that runs down to underneath the fuse panel cover it helps controle the functions you mentioned
1 - 5 of 5 Posts
