1 - 14 of 14 Posts
Any good threads on how to do this? I pulled a set of non tint glass at pick n pull this weekend to replace the ugly factory mirror tint. I pulled the weather stripping and just about everything else to get the windows out. There has to be a trick to get it in and out.
Straight out of the service manual:
Door Window Glass, Rear
Removal
1. Remove the rear door trim panel.
2. Lower the rear door window glass and remove the inside and outside rear door glass weatherstrips.
3. Note: Only one screw is shown in illustration.
Remove one screw at the top and one at the bottom of the rear door glass front lower retainer.
4. Remove the rear door glass run front lower retainer by pulling up and twisting so that the retainer bracket clears the rear door window opening and the rear door glass run slides off.
5. Pull the rear door glass run out of the rear door window opening.
6. Raise the rear door window glass half-way and remove the rear door window regulator arm from the rear door window glass channel.
7. Lift the rear door window glass up and out of the rear door window opening.
If you really need the diagram that goes with it, I might be able to pdf it. Hope that helps, Cheers!
Fixing Broken Stuff
I remember it was a little tuff.
STILL LEARNING
Bringing this topic back up.
I sold a set of my crew cab doors this weekend. I sold them as just shells, so I gutted them. I could get EVERYTHING out, EXCEPT the glass. I could NOT get the glass out of the door. They ended up going with the shell.
Do you have to take the metal runner off the bottom of the glass to get it out?
I couldnt turn the glass 90*, the door wasnt wide enough.
I want to put clear glass in place of my factory tint ones in my 97
Back from the dead!!
I FINALLY found some clear windows to replace the factory tint windows in the rear doors. I havent found much info on removal or installation. Any help would be appreciated.
I gotta admit I don't understand Patrick's directions. Maybe they will make more sense to me after I start tearing into it.
Here's some more info and diagrams (quality is probably not great).
For Rear Door Window, Crew Cab:
Item Part Number Description
1 25712 Rear Door Window Glass
2 25766 Rear Door Glass Run
3 25596 Rear Door Glass Outside Weatherstrip
4 24630 Rear Door
5 26228 Rear Door Window Glass Channel
6 23200 Front Door Window Regulator
7 N800510-S100 Screw, Rear Door Glass Run Rear Lower Retainer-to-Rear Door
8 N800510-S100 Screw, Rear Door Glass Run Front Lower Retainer-to-Rear Door
9 25804 Rear Door Glass Run Rear Lower Retainer
10 25796 Rear Door Glass Run Front Lower Retainer
11 25860 Rear Door Glass Inside Weatherstrip
12 23342 Window Regulator Handle
13 23370 Window Regulator Handle Plate
14 385189-S100 Rivet, Window Regulator-to-Rear Door
(3 Req'd)
15 23227 Window Regulator Handle Seal
For Rear Door Window Weatherstrips and Retainers, Crew Cab:
1 25596 Rear Door Glass Outside Weatherstrip
2 24630 Rear Door
3 25766 Rear Door Glass Run
4 25712 Rear Door Window Glass
5 25804 Rear Door Glass Run Rear Lower Retainer
6 N800510-S100 Screw and Washer Assy
Cheers!
  • Like
Reactions: 'Cody' and Zmann
I'm assuming you got this doen already but..... in addition to what Patrick stated - you need to remove the exterior door handle ( and machanism to give yourself some room and you will need to remove the 2 nuts holding the window in place in the retainer. Once that's done - rotate the window 90 degrees ( I rotated toward the exterior handle - not sure it makes a difference) then slide it out.
getting ready to do the passengers door - will try to take some pics or video
It's essentially the same process as the front door window - just no vent.
I posted the procedure up in #2 and #8 back in 2017, but here's the pages from the factory service manual. Cheers!
1 - 14 of 14 Posts
