1 - 20 of 52 Posts
Underfunded
I dont really have the ability to lift the engine up, so was wondering how folks have managed to mess with the oil pan while leaving the engine bolted down?
Thanks
can you drop the front axle?
OEM Moderator
I have heard of cutting out and rewelding in the cross member. I have done the oil pan on cars where there was no gasket and just RTV successfully with the motor installed. No way would I cut the cross member out on my truck to experiment.
A diesel shop local to me does this and has had great luck with it. I think they use some kind of frame jig to keep the frame rails 100% in the same spot, but I'm not sure. My buddy actually had this shop replace his rotted oil pan this way, seemed to work great.
Why would you even mess around doing this?
You can pick the engine in about an hour.
Well if I had to guess, a shop can replace a rotted pan a lot faster by getting out a sawzall, cutting the x-member, bolting in a new pan, and welding it back together. If you have a welder that is good at what he does, I think the whole job is far less labor intensive than pulling the engine.
OEM Moderator
Better be good welder to get that cross member welded up out of position under a vehicle. To the OP what is going on that you need to pull the pan.
Tom
Underfunded
Long story short I am trying to recover a piece of metal that fell in the pan... and have yet to have any success with my magnets, so I will get more magnets an attempt tomorrow.
Im not sure this will work however.
my truck is dead in the water so taking it to a welder is a no go.
How hard is it to pull the engine and other than an engine jack what might I need?
Does that cross-member bolt to anything?
PSN Pretender
How big is the piece of metal?
If it has any mass to it I would just leave it...........it wont get past the pick-up screen anyways.
Or do you need it back?LOL
Underfunded
Discussion Starter #14
its the dipstick assembly.... :mad:
PSN Pretender
Nahh........the oil pickup tube wont let you slide the pan out. You have to drop the pan strait down to get it out.
OEM Moderator
I think it is non magnetic so that will not likely work. Some have fished it out successfully in the past.
Tom
Recruit #211
I've never heard of anyone being successful at gettin pan off without pulling the motor completely out and if you do decide tp pull it i would suggest dropping the trans first cause you will have to drop it to put the engine back in and also if you have access to a tractor with a front end loader or a fork lift it sure makes pulling it much easier
Underfunded
Discussion Starter #19
Well i was removing the nut so I could use it as a reference when I made a outside gasket to keep that pan from leaking, since the original o-ring killed itself and the pan leaks.
1 - 20 of 52 Posts
