and some sane ones....we all have them..but usually there isnt enoughf time or monetyto try....ive had no less than 5 ideas i didnt act on and in less than a year someone else is makeing money on one of my ideas......so i decided to give SOME of them away...and possably open myself to public ridicule...but if it's good enoughf for my friend gregrob..then it's good enoughf for me.....ok here we go....#1 a perpeller attached to the driveline down by the diff, may help push the truck...heck they push-pull airplanes why not a truck....#2 how about getting an intake made, that would seperate the compressor side of the turbo..from the return from the cac...there is terrable heat soak there..then wrap the return from the cac with insolation to keep heat soak from the pipes....ok.ok the intake is already hot i know...but nor nearly as hot as the turbo....bet this would drop intake air bout 100 deg.....#3 this one is a dusey and brakes my heart do give it away....but the right guy could do this.....bromean is a refregerent that moves by heat you dont halfto pump it....so you wear soft copper around your exhaust many times ..there is your heat sorce...then to a dryer then wrap arount the cac return about 40 times and insolate it,that would serve as an evaporator then go to a condenser...weld all the joints and fill it.....and walla a super cold intake with no parasitic load on truck.....FREE COOLING...YA..ok enoughf ...except to say...i have more.....david.......
