1 - 2 of 2 Posts
dropped a valve on my 02 7.3 and it cracked the block. i got a good block out of a 97. my question is are the blocks different other then the fuel pump hole will my crank and cam from my 02 work in the 97 block?
Kmertz,
The blocks are a bit different. I believe the 02 crankshaft has a slightly larger counterbalance which requires some additional material to be removed from the block. Otherwise the blocks are the same, except for the already noted fuel pump hole. I would imagine that you could set the crank in the block and rotate it to find where you need to remove material. I have a pdf that describes the changes somewhere at home.
Cj
1 - 2 of 2 Posts
