1 - 5 of 5 Posts
Replaced the exhaust manifold. My 7.3l ran like a beast afterwords, at least for about 30 min. Put a can of engine restore in it. Started up fine, ran for about 3 min and quit! Replaced hpop again 4th one still no start. Even tried starting fluid, no start. Checked all the fuses, no start. Oil pressure sensor is new and ford motorcraft, pulled it out seemed ok. Pulled one of the hpop lines spit oil ok, I guess as I am by myself. I absolutely love this truck, any suggestions would be helpful.
PSN intsigator
Whats your fuel pressure, possible CPS issue... you got anyway to scan it. A CPS is cheap, less than 30 bucks from Ford.
PSN intsigator
Do you hear the fuel pump turn on, is the the filter housing full. If you drain it how quick does it fill up
1 - 5 of 5 Posts
