Helping a friend with a 08 f550 2ed auto 130k miles. Only code p1000. The engine was rebuilt 20k miles back was driving engine was getting hot they towed it to a shop they keep it for months never fixed. checked coolant no leak, I have checked it and the fuel smelled like paint thinner so I drained the tank flushed the lines then bleed it at the cooler until it cleared up then 2 gallons more. Lpfp 4psi hpfp 5700 on the rail 4500 desired injection 3* fuel valve 18% 220rpm batteries good, did a compression check on #1 was 337psi. Cranks and almost starts but won't like a 7.3 with low oil psi. I'm not familiar with the 6.4 do a lot more 6.0 7.3 5.9 so need a little help.
