1 - 14 of 14 Posts
Hey Everyone. I’m new to the diesel world and just bought a 97 F250 Auto. It was said to have needed a new PCM so I ordered a new one and put it In today.
I’m getting the WTS light staying on, no tach reading (with new CPS) and 324 codes. Most of them being circuit failure or malfunction or voltage supply circuit low.
But my scanner is reading 12.34 volts
Computer Font Personal computer Rectangle Gadget
Output device Gadget Luggage and bags Font Communication Device
Rectangle Font Output device Water Display device
Clear all the codes and then see what comes up.
What scanner are you using?
A few of those problems are not monitored by the PCM
Sent from my SM-A426U using Tapatalk
It’s all the same codes after clearing them... didn’t even have to crank for them to come back.
using an Autel Maxi pro mp808
Premium Member
99 & 00, F350s, manual and auto, Ext & Crew Cab, 4x2 & 4x4, need more room!
Welcome to PSN!
Get FORScan scanning software for Fords (free) and an OBDII reader. It is especially for Fords.
Those are strange codes. FORScan will tell you the real deal. Also, if all those "come back" without cranking, I would suspect your code reader for sure!
I doubt there are 324 codes defined for these trucks. But the transfer case shift motor certainly is NOT connected to the PCM, so that code definition doesn't even apply. We need to see the code NUMBERS (DTCs) - not the definitions (which are often wrong for these antiques on modern scanners). You also need to put ALL the truck's details & history (as much as you know) into your signature so it shows with each post, as this page explains:
1983 Ford Bronco Diagrams picture | SuperMotors.net
Phone apps don't always show signatures, so you may need to switch to a real browser in desktop mode on your phone, or just use a desktop/laptop computer. Put your location (nearest city) in your profile & upload an avatar of the truck. The more pics you post of the truck, engine, wiring, labels, & undercarriage, the more likely we can help you. Not all its details are relevant to these issues, but you don't necessarily know which ones are relevant, so just put everything in now.
  • Like
Reactions: LoganNatale
I don't believe that you scanner is coming up with correct codes for our trucks. 99% of the scanners out there will not read the codes on our trucks, you need on for Ford specific codes
As was mentioned there are a number of codes on your list that are not monitored by the PCM on these trucks, so they are false readings.
Look into FORScan Lite to run on a smart phone along with the ELM 327 Bluetooth adapter. FORScan Lite is a free app.
As for codes here is a link to what you should see, the code will start with a P such as P0603 which is a PCM code for Keep Alive Memory which will be set when the trucks batteries are disconnected.
  • Like
Reactions: Jax
Discussion Starter · #9 ·
thank you, I’ll try the different scanner.
what would P603 tell me? That the ecm isn’t working or is? Or were you just giving that as an example?
I think he was just giving an example. The P603 code is the Keep Alive Memory code that shows up when the batteries have been disconnected. Cheers!
Discussion Starter · #11 ·
I also have your typical autozone style scanner. Would that be a little better?
Premium Member
What @97F250HDXLT said!
Look, FORScan is free. I bought the license because I like it so much, but you do not have to!
I built my first truck (Here) and didn't know squat about civilian diesels.
FORSan has bee wonderful.
Now I am on my second truck . . . because I love these things!
Automotive parking light Wheel Tire Automotive side marker light Land vehicle
1 - 14 of 14 Posts
