1 - 5 of 5 Posts
So I'm about to go get my truck. Can I change a crank angle sensor in a parking lot, and can someone tell me where this sensor is so I know what I'm looking for.
Thanks y'all.
Discussion Starter #2
Foreal.
I'm leaving in the morning to drive 9 hours to the truck. I need to know please.
well you could change it in a parking lot, it is located on the passenger side of the engine, behind the A/C compressor, its held on by a 8mm bolt, you will have to do alot of it by feel since you wont be able to see the sensor very well.
Just out of curiosity, why is the sensor being replaced?
"resident smarty pants"
Are you getting an rpm signal? It is somewhat rare for it to fail.
I have read that a 16" ratchet extension and a pivoting adapter will get you to the bolt holding the sensor in. Long skinny arms are REALLY helpful.
I have also read about some folks removing the A/C compressor to access it more easily, but it really is a lot more work that way AND one bolt is at a horrible angle, so if you do .......... BE CAREFUL not to strip it.
Crank Shaft Position Sensor (CKP)
Ford Truck Enthusiasts Forums - bismic's Album: Miscellaneous Sensors - Picture
Page 52: Electrical Components
Awesome. Thanks guys.
1 - 5 of 5 Posts
