21 - 40 of 80 Posts
Member
Re: Cracked block serial #
5023250
Cracked at # 2 main from the outer 2 main bolt holes and down toward the cam bearing. 2001 @ 88K miles
Senior Member
5023250
Cracked at # 2 main from the outer 2 main bolt holes and down toward the cam bearing. 88K miles
What year truck was that?
What I want to know is why in the sam hail do I have a 6284541 in my 97!!! I'm gonna go balistic and keil someone!
Member
It was a 2001 forged
Senior Member
I'm doomed :confused:
Good lord man. Someone put a reman in it... Figured that would be obvious.
Senior Member
What the sam hail would be obvious about it unless i get under the truck and read the friggin number!!!
DI POWER
5023250
Thats my motor he's talken about:(
Keyboard Thug
What part of the number denotes it as a reman? I bought a block direct from IH for my 96, need to get the #'s. Somewhere in a notebook I have the #'s from the old block since IH needed them to source the correct block. Of course it didn't crack, it just broke the skirts off all the pistons and cracked both heads.:D Interesting thread nonetheless.
Senior Member
I had this truck for three years and never had no idea it was not a OBS engine till awhile back when I got curious and wanted to know the ser#.
I thought it was kind of funny having that high a number in a 97. That's why I am trying to get some feedback on what year it might have come out of. No way in the world to know if it was a reman or not. Gonna call Ford today and see if they can tell me anything.
Caption This
5023250
Something doesn't see right with those numbers. The last forged rod motor is supposed to be 1498318. My 2000 engine number is 1240???.
I guess the way I look at it is you either have an engine out of a newer truck or a reman/new engine was installed at some point. Doesn't really matter what exact year it came out of as long as it has forged rods. Externally the only differences are bolt ons. Pull the plug and look at the rods if that's what you are all worked up about.
DI POWER
Engine date was Jan 12,01. Must of been when they went to pmr then back to forged(mine) and then back to pmr. This is a very late date for forged. Truck was made July 01.
Caption This
To go from 1 million to 5 million in a year seems like a lot to me . I didn't know they could build 70,000 engines a week.
Keyboard Thug
I'm just starting to wonder if the block I got from IH was PMR or forged. Seems like I investigated this before and came up with forged, and IH did want the block serial # to source the part, so I'm assuming it was replaced with a forged rod block. Will the serial # give that info?
DI POWER
What ever it is it is, Those are the dates on the valve cover and door of the truck. I bought it new Sept 01. Truck was made in Mexico, maybe they stockpiled forged engines there.:D
Member
The engine serial number is correct just verified it.
Bigfoot is an OBS
Manufacturers frequently jump serial number ranges. Especially at model years or other significant breaks.
Usually production has an estimate of the number of units they'll build, so they allot a range of numbers for that build. The range will usually have a large increment. Say, allot s/n 1,500,001-1,700,000 for model yearl 2020, then 2,000,001-2,500,000 for model year 2021. In this case every model year jumps by one million, but that doesn't mean that one million were made.
Fierro Racing
larry i hope those are stock forged rods
21 - 40 of 80 Posts
