1 - 6 of 6 Posts
my temp runs up when i get on it, when i drive normally, it stays low to normal. I just changed the cap on the degauss bottle, when i park it after driving it for a while there will be no coolant in the bottle, but when i take the cap off it fills back up.... the top radiator hose is solid until i open the cap..... what could this be? my mods are in my signature
mine was the headgasket...sorry to tell you. You can check it by checking the pressure in the cooling system while driving it hard. If it exceeds 18 psi it is headgaskets.
yikeees
Wondering what if
If it wasn't for the normal temps, I would have suggested the thermostat.
so I guess I will be studding this thing and new gaskets.... anything else i should do? I will prolly do the oil cooler, and coolant filter at the same time.
1 - 6 of 6 Posts
