1 - 8 of 8 Posts
IM fixing to a coolant flush on my 2002 f250. Im planning to switch over to ELC coolant. What brand is recommended? Also im thinking about going ahead with a new thermostat and housing. Should I get O.E.M or aftermarket for these items? And what brand coolant filtration system should I buy dieselsite or sinister? Thanks for the help
Village Idiot
Google gooch coolant 7.3 all the coolant info you need.
as for coolant filters i like dieselsite.com
being an 02 your injectorcup seals should be fine..1999 should stick with green coolant for anyone else reading.
As stated above and go ahead and save yourself the headache and get the billet t-stat housing as well. I replaced it with an oem one the first time when I did my flush and it would still leak. Just added it to mine when I did the filter kit and replaced the water pump and all hoses. I had replaced the bottom inlet to the water pump and after I cleaned the surface to re-install, it leaked even worse so had to replace the water pump. O-ring seat and side walls that meet it were eatin up with corrosion.
When it came time to do my coolant system I debated on re-using the stock housing, therm, etc...for about ten seconds then did the smart thing that I wouldn't regret. I got the Dieselsite billet housing, 203* therm, waterpump (needed replacing), and also did their filter kit. Just flushed my coolant system yesterday and put in Rotella Ultra ELC. $95 bucks for 4 gallons at a local international/bobcat dealer. The techs up there said they run it in all of their international trucks.
Discussion Starter · #5 ·
Thanks for the help guys! Is the ball valves that are sold separate with the dieselsite kit worth getting?
I don't use them. I see it like this, as long as I have a working filter on the truck, i want it filtering.
Village Idiot
They make changing the filters easy and cleaner.....i would get them if it was me.
the international builtin filter has a lever on the pump.
or just wrap vice grips to protect the hose and give it a pinch shut.
i would spend more time tracking tools sleaves etc down
so that is why i would get them.
Discussion Starter · #8 ·
Thanks for the info. Could I wait and buy the coolant filter kit later on? I got a big tuition due for school in a couple weeks.
1 - 8 of 8 Posts
