1 - 2 of 2 Posts
So i started to smell coolant a couple days ago with the heat on. then yesterday i saw smoke or steam or some kind of haze coming from the vents with the heat on. today it smelled bad of coolant. parked came out and huge puddle of coolant under the passenger side dripping from the rear of the wheel-well (plastic wheel-well shroud) looked all over and cannot see where it is coming from.
Village Idiot
Sure sounds like it,
Could be a line where it comes in to the core , like the bypass valve if a o2 has one, but core do go bad.
If you empty glove box and squeeze sides in a little it will open straight down, maybe have a peek behind that.
1 - 2 of 2 Posts
