1 - 9 of 9 Posts
Hey yall, long time no see...
so IM sittin at 195k and thanks to me edge i can tell that its time for a waterpump, thermostat, and maybe fan clutch (the other day the oil hit 216 crusing at 65 on a very very long but extremely shallow grade like you can barely tell its a grade type of hill, so i turn around and went home before i got to the steep mountain)......ok so i know i need to do that but what i need to know is why the heck is there a very slow drip of coolant dripping on the passenger side FLOOR MAT!?
Discussion Starter #2
wow that was a ####ty post yall....sorry...wheres the edit button?
drip on the floor mat would mean heater core needs to be replaced.
OEM Moderator
216 is not crazy warm but warm enough I would be doing some checking.
Offical Puddle Displacer
what they said the drip on the mat is your heater core going. also you might not need a water pump or tstat, how old is the coolant? how many miles are on it it may be the only problem
yeah im definitely sure that was a factor cuz in the year ive had the truck i havent changed it and i doubt the guy i bought if from had in the last three or four so im definitely going to do that as well. but with 200k around the corner i figure i better at least think about it lol
oh and thanks for the help with the heater core, is that a hard install?
I find it pretty easy to hit 220F oil temperature (especially when towing, which I normally use the truck for). I'd say if your coolant stays normal, that your oil temperature is also normal at 216F on a hot day at highway speed and on any type of upward grade.
Discussion Starter #9
hmm any other opinions? im definitely going to change the coolant
1 - 9 of 9 Posts
