1 - 8 of 8 Posts
I have just done about $4500 worth of work to my truck including 2 new heads, head gaskets, ARP studs, sinister oil cooler, EGR delete and y-pipes and pretty much every gasket and o-ring on the top of that engine. So I get I back together and running and it runs great! The problem I am having is I'm getting coolant in my oil. I've already had the a shop pull the oil cooler pressure test it and check the o-rings, they said all that looks good and they said they looked at the front cover and noticed some cavitation but nothing that they said would cause my problem. I just want to know has anyone else ran into this and even if you haven't any little bit of advice I can get would be great. And by the way, I did not notice this issue before I did all this work. Thanks.
09 6.4
how many miles did you put on it? i guess the cooling system was flushed really well after having the heads off? how much coolant is getting in the oil?
The smallest of pinholes will cause coolant to get into your oil, if there is any cavitation whatsoever I can almost guarantee that that is your problem. I can even tell you how many I have replaced.
Well I drove it home from my shop (about 10 miles) then the next days I changed the oil again (did it before I stared the engine) and noticed the oil filter came out milky. So I thought to myself maybe I didn't flush it all out good so went ahead and changed it drove it 30 more miles and got under it and drop the plug to check for water and 1-2 quarts came out. So I flushed it again out of frustration and the same thing, another 1-2 quarts came out. I've got about 80-100 miles total since the build.
Oh and by the way as soon a I noticed the coolant in the oil I started just setting the cap on the degas bottle so it wouldn't build pressure. No change. And 06FX4 you say this is a common problem? I wonder why it didn't do it before the build, which was leading me to believe it was something I did :(. Only other option I could come up with was one of the coolant passages at the head gasket leaking into the pushrod galley???
The sheet I got with the studs said 70, 140 then 210 in the spiral pattern.... And I was hoping it wasn't a cracked (needless to say) but I think I might I might get a low to mild built long block to put in there. The truck has 280xxx and I just need it a good reliable vehicle out of it so if I just transfer all the stuff from the old engine I will basically have a new truck!! Only problem is that will put about 10k I've put into it within 8 months :/
09 6.4
ya final torque should be 210. i have experience with a cracked block on my 6.4....twice. my torque wrench, although almost new, was applying WAY more torque than it should have been. took 2 blocks before i finally figured it out.
i would definitely do a little testing and confirm the block is cracked before jumping to building a long block for it
1 - 8 of 8 Posts
