1 - 20 of 23 Posts
Jackleg Mechanic
Compound turbo and twin turbo are the same thing. What are you asking?
Village Idiot
In the 7.3 world of those choices compounds using various combos are 90 percent more common.
I only know of a handfull of true twins. Twins tend to be laggy.
compounds can be tricky to set up. However most have gone back to a good big single.
wastegates have come in more often now as well, on compound and singles.
my favorite combo is the procharger and turbo.
no reason to 'twin'
compounds are where it is at
Village Idiot
There are diferent sized turbos.
In the procharger version..small er gt38r for tow rigs.
gt45 and 47 for more performance race rigs etc.
compound wise a gt38r feeding a gt47 was a decent setup.
Village Idiot
Backwards..Air enters the#low-pressure#turbo#(the larger of the two) and is fed into the#high-#pressure turbo#(the smaller of the two), then directed into the engine or intercooler
In this case the turbo would be something like a gt42 or larger fed by the procharger..
in compound turbos the low pressure would be a gt47 fed by a 38 for example.
Village Idiot
Empire is the only outfit i know doing them.
I see empires kit uses a f1-d procharger which flows 1500cfm why wouldn't they use a f3a-123 which flows 3100cfm and can spin faster
Village Idiot
Have to ask empire that one.
Here for the party....
Compounds and twins are NOT the same thing...for the guy who said they were. And honestly, I wish that term would go away in the diesel world.
Twins, would be having say...two gtp38r's, or two s366's...one hanging off and feeding the left bank, the other feeding the right bank. Compounds are what the majority of the diesel world refers to, as twins..for some odd reason. A high pressure and a low pressure turbo. A gt4255 feeding a gtp38r, for instance.
Cummins called there compound turbo truck engines Twins.
KTTA
NTTA
twins do not need to be identical
Jackleg Mechanic
Thanks for the enlightenment, I stand corrected and am dang happy to be that way.:rockwoot:
Village Idiot
The key difference is not how many but are they parallel one for each bank.
or series one feeds another...or a combo of that.
you could have something with two small trubos feeding one big one etc.
Technically still compounds. If the output of one turbo affects another it is a compound setup.
If one turbo doesnt affect the other it would be twins.
You could have twin compounds, 4 turbos, 2 for each bank, one feeding another but not affectimg the other bank. But then you probably have enough money to not care what theyre called lol.
1 - 20 of 23 Posts
