1 - 6 of 6 Posts
I am converting my 2000 2wd dually over to an automatic. Everything you would need to install 6 speed in 2wd truck. Trans, clutch, flywheel, ecm, harness, everything.$1000.00
Off topic but Im wanting to do the same thing, where are you getting your parts and everything to do the conversin? How hard is it to do?
is this still availible? pm sent
It is sold. As far as the conversion goes, it definitely helps to have a donor truck. I got everything I needed from the donor truck. The hardest part of the swap is the harness. You have to change the entire under the hood harness. 99-01 trucks use the same harness, I don't know about 02-up. Not too bad if you have mechanical aptitude.
1 - 6 of 6 Posts
