1 - 5 of 5 Posts
Hello, I have been having problems with my 7.3, it will not start in the cold it will only start if it's been plugged in over night or if I spray ether. I replaced the glow plug relay and it didn't help the issue. Is there anything I can test or check? It's getting annoying. Please and thank you
Renegade Diesel
first off DO NOT use ether on these engines with the glow plugs it can explode prematurely and well you could toast your engine real fast.
i would ohm out your glow plugs to see fi they are all working.
replacing the relay wont do anything if the glowplugs are bad
Fixing Broken Stuff
Do what these 3 guys ^^^ said, if that's not it then your injectors are most likely worn out.
1 - 5 of 5 Posts
