1 - 2 of 2 Posts
WNY Biodiesel Co-op
Is the clutch master cylinder push rod removable on a '95 F250 or is it permanently fixed in the master cylinder. Thanks
There's a snap ring that holds it in place. The replacement's I've bought, the pushrod is separate, but once you put it in, it's a PITA to remove. IIRC you can't get a regular snap ring pliers in there, since it's kind of recessed; I had to just sorta force it open with a screwdriver.
1 - 2 of 2 Posts
