Hey all 1st post here. I've been doing a lot of reading but I can't find a solution to my problem. When I drive my truck slow, I can hear a clunking sound in my front end. It almost sounds like a shock is loose but I just put new Bilstiens on it a month ago, and I'm sure the mounting bolts are tight. I have new Spicer ball joints installed on the passengers side but the drivers side was good at the time of installation (1 month ago). I also have a new tie rod end (long one from gearbox) and it was just aligned. I had my wife turn the steering wheel back and forth while I checked the steering linkages and the only slack I could find was in the shaft from the column to the gearbox but it was nominal at best. The u-joints were tight and all the tie rod ends looked tight too. I even rocked the truck when it was parked and I couldn't duplicate the sound. It only seems to happen when I turn a little bit. Sorry for being so long-winded but I want to cover all that I have checked. Thanks for any help you can offer.
